time2roll
Sep 11, 2020Nomad
HioSSilver wrote:While this is probably the most direct bolt in replacement and is way better than the 6325... may not be what you are looking for. Temperature compensation is good and really only needed in extreme conditions and plugged in full time. If you charge with a generator you are better off with a multi-stage converter that initially boost charges at close to 14.4 volts.
Just talked to randy. He recommended the magnetek 8300 45tcru. So i ordered that.
Thanks for the replies.
