2manytoyz
Jun 09, 2015Explorer II
Shouldn't matter. The generator will run as fast as the load demands. In eco-mode, or running wide open, still producing 120V @ 60Hz. There's more current available at the higher speed, but if the charger doesn't require it, it's of no benefit.
If you're trying to do a fast charge to limit generator run time, you should consider getting a battery charger such as an Iota 55A model. It can do the 3 stage charging to prolong battery life, but it also comes with a plug to kick up the charging voltage to 14.2V, and will not reduce like a smart charger. Much faster, but you need to watch your batteries and make sure they are not boiling.
More detail can be found on page 3 of the Iota owner's manual:
www.iotaengineering.com/pplib/dlsmanl.pdf
44,068 PostsLatest Activity: Jun 20, 2026
