Go_Dawgs
Jul 17, 2013Explorer
Charging batteries
I think my Intellipower 9200 converter/charger is toast on our AF990. I need to get a multimeter to verify but in the mean time I unplugged the converter from the 110 outlet that it is plugged into (when connected to shore power) and the outlet is fine and in working order.
In the mean time I have a question on charging the batteries. I have two group 27 batteries wired in parallel in the camper. Since my inverter/charger in bad and does not charge them when I am plugged into shore power can I simply hook up my 15amp Stanley battery charger directly to one of the batteries? Do I need to disconnect the batteries individually and charge them individually? Or can I just hook up my charger to one of the batters and both batteries will charge?
Also, I have a battery disconnect switch under the sink, should I flip the disconnect switch while charging? I wouldn't think that would be necessary.
So far I have left the batteries as is (connected and wired in parallel) and not bothered with the battery disconnect switch. I have hooked up the charger to the front batter and let it charge. Once the batteries are fully charged the charger goes into a trickle charge mode. Everything seems to be ok, running fine but I figured I should ask and get some opinions.
Thanks for the help,
JT
JT
