enblethen
Nov 14, 2014Nomad
Yes, it should charge to some level.
It will depend on how it is wired. It should be wired with a good sized wire so as to reduce voltage drop. It should be in the neighborhood of #8 and maybe # 6 for both positive and negative. It should have a relay based isolation relay rather then a diode based.
You need to make sure that the camper does not have a switch that needs to be in a certain position.
44,070 PostsLatest Activity: Jul 21, 2026
