Dakota98
Nov 14, 2014Explorer
Blanco1 wrote:
Personally electrical has always been my weakness, I just wanna make sure my battery will be strong enough to keep the furnace warn through the night while out in cold temps.
You should be OK. But take along a multimeter & check the battery voltage when you arrive at your destination, then check it again in the morning before you set out once more. You'll see how much power you've consumed through out the night & have a much better idea of what your true needs are, if any beyond that. The furnace will drawn a lot of power over a 12 hour period if used extensively. Take several blankets.
44,070 PostsLatest Activity: Jul 22, 2026
