Reddog1
Nov 14, 2014Explorer II
The onboard geni might be your answer, or maybe the Yamaha if you can run them while on the road. You may have less drama than I did, especially you can run the onboard 2.8 Geni while driving. I would even consider running heat while on the road and charging the batteries. With the inside of the TC warmed, you would need less heat at night when the generator is not running.
44,070 PostsLatest Activity: Jan 14, 2013
