Blanco1, we are getting off of the topic of "Charging the camper battery while driving?", but is related to finding solutions to heating the TC. If you want us back on track to your initial question, please tell us.
HMS Beagle wrote:
Question on the Wave3 and cold nights: on my current Bigfoot, there is a forced air heat duct up in the cabover (though the run is long and the flow unimpressive). Even so, it gets pretty cool up there on cold nights. This is the 10.4E model, with forward bath and pantry, making the opening to the cabover bed much smaller than it was on my previous 9.6, which was more typical of camper layouts. In that one, even without an air duct up there, it stayed closer to the temperature of the dinette area which is where the thermostat is.
Obviously, my 1988 Bigfoot is laid out differently than yours. I do not have a duct to the cab over, but do have one to the holding tanks. It is pretty useless when using the Wave heater only.
HMS Beagle wrote:
With the Wave and no air circulating, would it do much to keep the cabover area warm? This is going to depend on camper layout, maybe someone with a similar layout has installed a Wave and can comment. One could always run a small circulating fan, but that takes power too.
The opening to my cab over is wider than yours, but I think you would find that with the cab over windows opened about 1/2-inch or so, the warm air below will heat your cab over. I have an escape hatch in the ceiling of my cab over. I usually have it open a little also. I can also use it to control the heat from the Wave. I find this to be true using the Wave and/or furnace. I do have a switch I can turn on the furnace without getting out of bed to boost the heat, if I am running the Wave only.
I have considered a small computer type fan just to keep the air circulating in the TC. Hot or cold I think it is a good idea, but as you pointed out, takes power. Opening the windows a little has done real well, provides fresh air, circulates the air, reduces the condensation, and reduces the combustion byproducts. I typically leave the dining table window (has a vent cover) open an inch or two for additional fresh air, and I seldom completely close the bathroom vent cover. I do this pretty much year round.
HMS Beagle wrote:
Second question: since it is manually ignited, no thermostat is possible - do you just leave it on all night?
I leave it on all night if I think it will be needed. I have learned that I can usually run the Wave3 on low, and set my furnace thermostat on 50 degrees. During the night, if the Wave3 does not keep up, the furnace will kick in. I might then close the escape hatch, and close my cab over windows to about 1/2" opening. If during the night the Wave3 is too hot and I wake up I will open my cab over windows or escape hatch more. I seldom have the furnace kick in, then only once or twice in a night.
If it is really cold, I will run the Wave3 on its highest settings, and use the furnace thermostat control as a backup.
HMS Beagle wrote:
Third question: the Wave is unvented, which means that the combustion byproducts end up in the camper. Chief among these are water - quite a lot of it. At 3000 BTU for 10 hours you will produce a little under 1/2 gallon of water. I have had serious moisture problems when heating buildings with unvented propane, and often moisture and condensation control are problems in winter RV camping. Do you see any problems from this? You would have to keep windows/vents open to vent the CO2, maybe that vents enough of the water vapor too.
I have condensation in my TC, but it has never proven to be a problem, and my TC is over 26 years old. We even use our stove top and oven. I insist on venting my camper. Even without heat the air gets stale, and if you breath you will lower the oxygen in the air, create condensation, and increase the CO2. Your TC gets to smelling bad also. I prefer to sleep in 55 degrees or less, with lots of blankets.
As a side note, I have a tent cot I use when wheeling. Even with no heat, it will rain rain inside the tent. I wipe it down with a towel, before I get out of my sleeping bag.
HMS Beagle wrote:
There are vented catalytic heaters, which mitigate these problems but use some power (though not very much) and cost more.
It does not mitigate all of these problems, but does reduce them. I will argue that if you use your stove to cook and/or breath, you will have condensation. Unfortunately, the whole truth is not always told on the vented catalytic heaters. Look closely at the design.
Wayne
