blt2ski
Jul 13, 2013Moderator
One is also better off with a chassis cab, as it comes with light wires etc ready to install after market beds, where as the box removed, the wires etc are only set up for the box. Along with being as you usually do not have a installed door placard, the aftermarket body manufacture is in charge of installing it. You can do other things to the truck, to increase gvwr, put a full gvwr equal to the axel limits, put a tag, drop or other axel on it, and increase gvw too!
At the end of the day, besides what other have mentioned on the frame etc, the above helps and makes it better to do a chassis cab vs box delete option!
Marty
Marty
