transamz9
Jul 15, 2013Explorer
The cab and chassis trucks have heavier frames and usually more spring under the rear. The GVWR is usually the same but the difference is that the CC trucks will handle the GVW better. They are designed to run around loaded 100% of the time as the regular trucks are not. My 06 CC service truck weighs 11-13,000 everyday. It has a GVWR of 13,000. It handles the weight like it's not there.
I will caution through. I recently owned a 2010 CC 3500 that I just had an aluminum flat bed on the I occasionally towed a heavy goose neck trailer with and the unloaded ride was almost unbearable on the hwy. It took about 2000lb on the back to make it even start to ride okay.
44,070 PostsLatest Activity: Sep 18, 2026
