Gjac
Sep 27, 2019Explorer III
TurnThePage wrote:I thought this may be the case. If they use the same cross section and same thickness it should be stronger. Is there anyway of finding this info out? Bert mentioned LCI, who else makes these frames? who makes the frames for the ORV trailers?
When I was trailer shopping, I noticed that shorter trailers usually ended up with relatively stronger frames. That cheap I beam works fine for 20 or 25 feet, but gets weaker the longer you go.
