profdant139's avatar
profdant139
Explorer II
May 31, 2014
Check trailer's tail lights on BOTH sides before towing
Just after hitching up, we always check to see if the electrical connection between the tow vehicle and trailer is working. Usually, I just flip the turn signal, and DW verifies that the rear light is flashing.
The other day, I put on my hazard lights when we pulled over to the side of the road, and I just happened to walk behind the trailer. To my surprise, the light on one side was flashing, but not on the other. My first thought that a fuse had blown or that the LED panel had gone bad. But on the "why not" theory, I unplugged the seven-pin connector on the rear bumper of the truck, saw that it was dusty, blew on it, wiped it on my jeans (why not??), and plugged it back in.
That fixed the problem! But I am surprised that the connection to one of the rear lights could be imperfect while the other one was functioning properly. In any event, I have learned my lesson -- before towing, make sure that BOTH rear lights are working!
  • Yep, sometimes my right turn signal light does not work even though the left does. Unplug and replug and it usually works first time. Dirty or loose connection I guess. Have not followed up on it yet.
  • RoyB's avatar
    RoyB
    Explorer II
    I squirt alittle dab of WD-40 into my truck connector and move the trailer plug around a couple of time. Then I always turn on lights flashers etc and do my walk around before leaving...
    I also stop my truck and trailer at the first stop sign in my neighborhood by only using the electric brake manual brake thumb lever to tell my the electric brakes are working ok...
    Have done this since day one of pulling anything...
    Roy Ken
  • I do almost the same as Dog. I turn on the parking lights, and the 4 ways, and check every bulb. I installed LED Fixtures in the back of my TT.
  • If you turn on your headlights and four way flashers, you can check the function of all the bulbs at the same time.
    That is what we do before pulling out. We do have standard bulbs, your LED set up may be different.
