StevenBigBear's avatar
Aug 10, 2013
CHECK YOUR OIL
CHECK YOUR OIL; This week I took a leisurely drive up to Joshua Tree and when I got to my friends house, I heard an unusual knock coming from the engine in my favorite car. I got out to listen more closely and SNAP...Through a rod.
The Excursion is perfectly maintained except I failed to check the oil recently and it was bone dry. The truck is going in for an engine replacement on Monday. 6+ GRAND. The truck went from perfect to worthless, because I let a simple oil check pass.
ALWAYS check your engine oil. I am pretty good about this, but since the truck has more than 100 thousand miles on it, it has been using more oil, about a quart per tank. I am told this is normal for a 10 cylinder engine.
I love this truck and plan to own it for the rest of my life, so I am going to pay to have it repaired. The truth is the truck is worth less that the cost of a new engine. I can't let it go, it's like an old friend so I am going to get it fixed.
Check your oil...
  • I have 7800 miles since the last oil change on my excursion. I have been changing the oil every 6000 and it never uses any. It is down almost a qt so I will change it soon. It is a V10 with 159,??? Miles. A V10 should not use oil between oil changes so yours was already on the way out.
  • Hopefully you are replacing it with the newest version of the 6.8L V-10. I do not agree that using a quart of oil that frequently is normal either. Sounds like something was going on with it anyway. You will still have a great TV when it is replaced. I love my V-10 powered F-250. Thanks for restoring a great TV rather than junking it.
  • When I was working in El Paso I would take my truck (Sonoma with 95k on it) in for a combination car wash and oil change on a coupon. On a trip to San Antonio, after about 300 miles of 80 mph driving, the transmission fluid boiled over. Turned out they were changing the oil but not checking other fluids or items like a normal oil change business so the fluid had gotten extremely low. I put in a couple of quarts of t-fluid in Junction and had the transmission rebuilt when I got home. So now I'm not too lazy to check all the fluids before I head out on a trip.
  • Good reminder!
    Don't know if it will make you feel any better but the price of a new tow vehicle of that size is a wee bit more than $6K, probably $40K more.
