Anonymous
Jul 16, 2017Not applicable
choppinwood wrote:
Good idea... while im up there, seems those shrouds should have the screens in them already. Can i ask you how you attached them? Inside it.?
Attach it to the inside of the cover. I've had good luck with caulking. I ran a bead of caulking and pushed the mesh into it. I've tried epoxy which holds the mesh well, but the flex in the plastic caused it to crack and loosen over time. Good ole nuts, washers, and small bolts work well too.
44,070 PostsLatest Activity: Jul 21, 2026
