Kayteg1
Jun 10, 2018Explorer II
Scott Central Oregon wrote:Kayteg1 wrote:
I found few times that check valves on pumps deteriorate with years and they can leak the water back to the tank.
Good idea to buy rebuild kit every few years.
That wouldn't apply to my 6 mos old camper tho.
The short cycling began after a boondocking trip up 10 miles of rough road. I would have thought that plumbing fittings would be sufficiently robust to tolerate a rough ride but perhaps not.
It might if you have chunk of "factory dirt" stuck to check valve.
I like Sherlock Holmes idea of getting final conclusion.
When you check everything and the unlike is the only possibility left = the unlike has to be the truth.
44,052 PostsLatest Activity: Oct 14, 2025
