Wardster
Jun 18, 2018Explorer
Scott Central Oregon wrote:
There are no visible access to the plumbing in the wet bath/outside shower. If there's a leak there I don't know how one would see it let alone repair it. The bath is a 2 piece plastic insert, no small task to remove.
You can see most of the plumbing in/around the outdoor shower/bath by simply shining a flashlight inside through the access door to the pump/valves. If something is leaking, then I would have the dealer handle it under warranty. If it was out of warranty, then you can access the outdoor shower plumbing by removing the medicine cabinet in the wet bath.
44,052 PostsLatest Activity: Oct 14, 2025
