Taco wrote:
The 5.3 and 6.0 are both good engines. I wouldn't make my decision on the engine, they both have enough power to get to where you are going. I have a 2012 6.0 and I am satisfied with the power and towing performance. It is on the thirsty side 12 mpg mixed city, 16 mpg highway, 8.5 mpg towing 8k lbs.
I have had both 1/2 and 3/4 ton and the 3/4 ton truck can handle a lot more load/trailer than the 1/2 ton. From the sounds of it you use a truck like a truck and need one that can handle some load.
A 1 ton srw would also be an option to consider, it would be basically the same as the 2500 but cost a few 100 more and able to haul a few 100 lbs more.
For the '13/'14 models, when I priced the 2500HD vs the 3500 option for option, it was atually CHEAPER by a couple hundred for the 3500!!! Standard tow pkg and tow mirrors being a good part of the reason. Not sure how '15 pricing will be.
APT wrote:
Keep in mind the tow rating for the 6.0L/3.73 is only about 9500 pounds. Going to 4.10 bumps it up by a good amount, about 14k. The 4.10 can be hard to find new and used. As you search, look at the RPO sticker in the glove box for one of the following:
GT4 - 3.73
GT5 - 4.10
You may want to wait to see what the 2015 HD has to offer. You can already order one now for delivery early next year. I expect the gas engine to be significantly more powerful than the 07-14 6.0L.
From everything I have read, the 6.0 will continue in the '15 HD's. it will be interesting to see what the replacement engine will be.
Statefan,
We recently stepped up to our '13-2500HD from a '10-1500 5.3/6spd/3.42/4x4 ccsb. Payload was the reason for it. Motor for motor they both are very good! Not a huge difference in power (noticeable, yes), but more stable, and slightly more thirsty! Lol This w/e we are in Northern Mi, 200 mi trip and got about 14mpg. Temps were 10*-22* for the trip, so there is 1-2 mpg there. PLUS- we don't have a topper or tonneau cover yet, so that great "air bubble in the bed" (as proved by Myth Busters in an empty truck bed) is disrupted by the rubbermaid tubs in the bed of the truck. we would usually average about 15mpg, to maybe 16mpg (if lucky) for the same trip in the Winter for our 1500 if I remember right!
The 14's have the 4.10 gears standard (3.73 is an option now) so it may be a little easier to find a truck with them!
Good luck!
