Groover
May 16, 2019Explorer II
AlmostAnOldGuy wrote:BillyBob Jim wrote:Groover wrote:
There is a reason Chevy likes to compare their 2.7 turbo to Ford's 3.3 naturally aspirated engine.
Which is?
The Ford 2.7 turns in some good numbers. But if you otherwise like the Chevy this engine may do just fine depending on what you tow.
Chevy 2.7 I4 turbo - Al block
310 hp
348 ft lbs torque
EPA 20/19/22 - 4WD
Ford 2.7 v6 turbo - CGI block
325 hp
400 ft lbs torque
20/18/23 - 4WD
Take it easy,
Stu
Also,
Chevy CC 4wd towing 6,700lbs
Ford CC 4wd towing 7,600lbs unless you get the max payload then it is 8.900lbs but that is rare.
Plus there is always performance:
TFL 2.7 turbos compared 0-60
