jerem0621
Jul 19, 2016Explorer II
JIMNLIN wrote:Walaby wrote:
I think all rhagfo is saying is the 2500HD is basically the equivalent of a 3500HD but badged as a 2500. If that is the case, then kudo's to GM.
Maybe I read it wrong, but that's what I thought he was saying.
People sure are thin skinned these days.
Mike
You read it right. Its more than just being thin skinned in this case.
The newer gen 250/2500 trucks in some cases are mechanically the same as a 350/3500....with exception of the rear main spring package in some cases and tires and wheels when looking at each mfg spec sheets.
I think that's exactly what Russ is saying.
The only real exception to that rule is the Ram 3500 SRW and the Ram 2500 SRW starting about 2014 when the 3500 had the leaf spring rear suspension and the 2500 went to coil springs and a 4 link (IIRC, I can't remember what # of links there are.)
Sometimes there are different tiresas well...not much of a big deal.
I like the men from the boys comment...like a truck makes a man...Hahahaha...it doesn't...it's just a tool...that's all...just a tool. A very expensive tool.
Thanks!
Jeremiah
