falconbrother's avatar
falconbrother
Explorer II
Mar 03, 2017
Chevy 5.3 oil capacity quandry..
I bought a used 2000, 1500 Suburban 4x4 with a "new" (40,000 miles) engine from a wreck in it. Long story but, my wife picked it out, test drove it, etc.. She's actually pretty good at that, historically. I was too busy with work to fool with it. When I checked the oil the first time there was just a drop at the tip of the dipstick, which got my jaw tight.. I added two quarts to get it to the full mark. The oil in the pan was fresh and new and I could find no leaks and it wasn't smoking so.. I changed the oil the other day, added exactly 6 quarts, which is what 00 - 06 5.3s call for, and at 6 quarts it barely touches the tip of the dip stick.
I thought that maybe I had the wrong dipstick but, it really looks like the appropriate one.
Doing some research and it seems that 2014 and later 5.3s use 8.5 quarts of oil. Could they have bolted a 2014, 5.3 into a 2000 chassis/4L60e transmission? I suppose I will try and search out the VIN from the engine block and see what it will tell me about the year model that the engine came from.
It's fun to play with anyway and runs perfect.
  • My first thought was an aftermarket higher capacity oil pan added during the engine swap or too short of dipstick. But a newer engine is certainly a possibility because crate engines from a dealer or source like Summit is a common swap.
    My old truck 7.4L chevy would use a quart of oil every 1000 miles with no visible smoke. I added a product called Restore, it's an oil additive at auto parts stores. It stopped burning oil after 500 miles.
