jamesu's avatar
jamesu
Chevy diesel questions and concerns
Not sure if this is the correct blog category but I'll start here.
I bought my used 2011 Chevy Duramax/Allison tranny a year ago. Love it. It was the first diesel I had ever driven, and because of that I believe that I am still learning stuff. I heard/learned some stuff the other day that I am considering which I will relate here.
My neighbor has basically the same truck as me: a 2012 GMC Denali Duramax/Allison tranny. He is towing a large 5th wheel and has had several diesels before this. You can see my TT below in my signature.
When I tow I always push in the "tow" button at the end of gear station. My neighbor only pushes his button when going up hills and mt. passes.
When I tow I have rarely used my jake brake, thinking that the gearing in my "tow button" position is sufficient when descending hills/mt. passes, having heard that my Allison transmission is "bullet proof". When towing my neighbor immediately pushes his jake brake button when he starts the engine and keeps it on all day.
My questions: Who is towing correctly? By keeping his jake break button activated all the time is his engine at any risk? Or are my brakes/transmission at a risk because of the way I rarely use my jake brake?
I have searched my truck's owner's manual and also the internet for answers to these questions and neither was much help to me.
My dashboard readout states that my average overall MPG is 15.2 mph while my neighbor's overall readout is 18.1 mph. Neighbor says it's because I am using the "tow button" feature when I am towing, and he is only using it when the tranny starts "searching" going up hill.
Feedback to my questions and concerns are appreciated. I have a great tow vehicle, and I want to get the most out of it when towing and I want to be able to be towing with it for a long, long time.
Aside: I am, and have always been, a stickler for keeping up with planned maintenance on all of my vehicles.
  • Read the manual and use the buttons, and don't listen to nonsense.
    Now about the fuel mileage, learn how to reset the readout at the beginning of a tow. Both of you are getting far less MPG than you think.
  • Cummins12V98 wrote:
    Your neighbor does not have a clue!
    When towing ALWAYS use TH and EB. I run them ALL the time, I hardly touch my brakes running solo.
    this, read the manual
    I have to agree with the above. The TH has two advantages, it extends the shifting points in the transmission and enables grade braking. TH enables the transmission to operate at lower temps.
    While towing if you consider the EB as the primary brake for the vehicle it will make a lot more sense to use. On a commercial tractor and trailer (80,000) the EB is the primary brake, so why not utilize it on your RV/FW when towing?
  • Your neighbor does not have a clue!
  • Tow/haul..........
    It lengthens the shift points on acceleration and downshifts sooner on deceleration
    Exhaust Braking......
    Allows for engine/tranny braking/slowing of truck w/o having to use service brakes as much
    Use them as you want.....especially with that light weight trailer (7600# GVWR)
    I tow heavy so I always turn tow/haul and I turn on EB when in mountains
    But sometimes I use EB when not towing same with tow/haul
    IF your exhaust brake is part of turbo (variable vane design) then turning it on/running with it on helps keep it functioning better
  • Hey,
    Here is how I tow my TT - I have a 2013 Chevy Duramax.
    As soon as I leave with my trailer connected I press my tow button and put on my exhaust brake. Works great. My understanding is that the tow mode keeps your RMPS a bit higher so that your truck doesn't have to shift or work as hard. Personally, I believe they put that tow mode on the truck for a reason - use it! As for the Exhaust brake, I live in a hilly area, so I love using it. It feels solid and safe. Just my two cents...Good luck!
