Bedlam
Sep 17, 2019Moderator
time2roll wrote:
I honestly would not plan a trip where more than one charging stop en-route was necessary for all the reasons mentioned. I think they could have done better to charge to full 100% at every stop but again that takes even more time. Probably 300 miles per day is a practical limit when towing. Even then you need a smaller and low profile trailer.
With any luck the Tesla/Ford/Chevy trucks will have 500+ mile range so that 200 towing will be possible. Probably not the first batch.
One of things I wonder about is charging time with a higher capacity battery array. Will there now be 3 hour recharge times rather than 1.5 hours if I can double my range? At the start of a charge cycle you can dump in amperage much quicker than when at the top off stage, so I know this is not a linear time to capacity line but at some point you will be hitting the limits of what the charger can supply and the maximum input charge amperage the battery chemistry can absorb.
44,070 PostsLatest Activity: Aug 07, 2026
