skipnchar
Jun 19, 2013Explorer
How do the DOT safety plate numbers for the two vehicles (trailer and tow vehicle) match up? That would determine is you're SAFE towing with that van. How satisfied you are with performance is a personal matter and can be determined by simply hitching up and taking it for a drive.
For safety concerns just make sure your payload numbers match up well with the load you carry in the van and the fully loaded tongue weight of the new trailer (weigh it or for extimate purposes, use 15% of GVWR). Then check the axle ratings on the van to be sure you're not over THOSE ratings (again from the DOT safety plate).
Good luck / Skip
Good luck / Skip
