RoyBell's avatar
RoyBell
Chicago RV show- 1/2 tons can tow 8500lb 5th wheels.
I visit this show yearly. I hate that it's hard to find anything, but enjoy looking at the campers nonetheless.
Lot of 5th wheels there this year, seemed quite a bit more than previous years. Walked by the General RV section and all their 5th wheels had pictures of half ton trucks with "your truck can tow this" wording, followed by the dry weights of the campers. 7500, 8000, 8500lbs :E
I can only imagine what the pin weight of a 31' 5th wheel ready to camp is. Scary advertising out there.
  • 8500lb camper DRY is a 2125 pin weight (25 percent). That Dry camper probably really weighs around 9500 ready to camp- 2375 lbs.
    Even if you have a 7000lb camper in real world, that pin will still be right around 1700 lbs. Add 2 passengers, a bottle of water, and your hitch of choice and you are now exceeding that "2000 lb" Payload capacity.
    Not to mention GVW, Axle ratings, and the Passenger tires they put on half ton trucks.
  • rhagfo's avatar
    rhagfo
    Explorer III
    CKNSLS wrote:
    The payloads on some of the half-tons now are at 2,000 (plus) pounds. So yes-they could tow a fifth wheel at 8,000 pounds guys.
    It's a new world.......
    ^^^^^ This, and I would rather see an F150 carrying a 31' 5er then towing it.
    I think you can find some pretty long light weight 5ers if you look, way safer than a long TT behind an F150.
  • The payloads on some of the half-tons now are at 2,000 (plus) pounds. So yes-they could tow a fifth wheel at 8,000 pounds guys.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    It's been going on for years; My old Tundra was rated to tow 10,000 lbs, so that must mean it can tow a 10,000 lb fiver, right? Wrong! It was a Crew Max with the lowest payload rating of 1325 lbs so I would be way over the payload rating and even the gross rear axle rating. For some reason, the RV dealers are allowed to get away with this.
