TurnThePage wrote:
I recently had an issue with GPS not working correctly. There was an update available to fix it, but it was failing to automatically download and install. I was able to go to the Uconnect website and download and install it myself. But some people have been unable to do that and had to manually jump through some hoops that eventually enabled them to download the correct file and fix the issue. If that's your problem, you could probably find the solution on ramforum.com.
I would hope that being to the dealer over this they might know these tricks.
