- OzlanderExplorerWell, no body told him he had to open the door to get into the glove compartment.
- Sport45Explorer IIAnd it only took 5 months... :)
- boston_blackyExplorerI did do as mkirsch said and looked in the fuse box under the hood. Replaced fuses and all is good. Thanks mkirsch. bb
- mkirschNomad IIWow. Okay, you go with that. Have fun tearing apart the truck looking for that inline fuse that doesn't exist...
Seriously, the fuse is right there where DirtyOil's picture shows.
If you still can't find it, take the truck to a mechanic. - 2oldmanExplorer II
mkirsch wrote:
Very handy device.
The truck's owner's manual also describes where the fuse panels are, how to access them, and what the functions of each fuse are. . - boston_blackyExplorerThat's all warm and inviting. There's a direct feed from the battery to the power outlet(s). Me thinkx!! Those leads (two) may contain 'in line' fuses - me hopes! Once I get the fuses - I'll let 'ye all' know. Again thankx for the h e l p. bb
- mkirschNomad II
boston blacky wrote:
I did check on the dash board - driver's side. Still unable to find anything inside; i.e. such as a 'panel' or similar fuse box. Under the hood is the only place I can find anything showing a "fuse and relay" label. It wouldn't be there - par chance?? bb
Why don't you lift the cover off and look? Nothing is going to spring out at you.
The truck's owner's manual also describes where the fuse panels are, how to access them, and what the functions of each fuse are. The owner's manual is generally located in the glove compartment of the vehicle. The glove compartment is in the dashboard on the passenger's side, generally at or above knee level when sitting in the seat.
If you do not have an owner's manual, it is a wise investment. They can be ordered online or from your local Dodge dealer. - DirtyOilExplorerthe fuse box is located at the end of the dash board,(on the side of dashboard between the dashboard and door) reason why you have to open the door, there is a door on the end of the dashboard that you have to "pull" off. on the back side of that door is the "diagram" and list of fuses.
- boston_blackyExplorerI did check on the dash board - driver's side. Still unable to find anything inside; i.e. such as a 'panel' or similar fuse box. Under the hood is the only place I can find anything showing a "fuse and relay" label. It wouldn't be there - par chance?? bb
- DirtyOilExploreropen drivers side door, on the side of dash board there is a fuse box pull the cover off. on the inside of the cover is a list(diagram) of fuses, the cig lighter will be labelled "power outlet", the cig lighter and power outlet share same fuse. I believe its a 20amp fuse.
44,068 PostsLatest Activity: Apr 17, 2021
