Artum_Snowbird
Feb 18, 2018Explorer
Take the city water off and run the pump. If flow seems weak and pressure does not build up, you have the valve that others mention. I had one like that. It needs to be in the off position to prevent tank fill, and to allow pump pressure to build up when on pump only. If in the fill position when on pump, water just recirculates back into the tank and out the pump again.
good luck.
good luck.
