SoundGuy wrote:
Old-Biscuit wrote:
WHY you ask..........Because it is a cheap plastic piece of junk assembly.
#1nobby wrote:
This is the only explanation I accept.:)
#1nobby wrote:
Anyways....either way.....I'll be more careful next time with that step of winterizing and will install a new flange in the spring.
And the new one you ordered will be just the same. :W  In future, push the check valve stem under sufficiently reduced pressure and you won't have this issue again - "cheap plastic piece of junk assembly" that it may be. ;)
If you're going to quote....try and get them all.
