_1nobby's avatar
_1nobby
City Water Flange
Whilst winterizing my TT, I made sure that the RV plumbing anti-freeze went everywhere it needed to go, including the city water
connection.
How did I do that, you ask?
Well, with the system almost fully pressurized with the on board water pump, I pushed in the check valve of the city water connection which forced anti-freeze into the line and out the valve.
Great!! Worked like a charm!
Except that in doing so, the internal "O" ring was dislodged thus rendering the check valve kaput.
So I decided to do some NDT on the valve to see the what for.
Kidding.
Once apart, however, it still leaves me shaking my head to WHY the "O" ring would get dislodged. It sits in a very deep groove of the actual valve.
Anyways....either way.....I'll be more careful next time with that step of winterizing and will install a new flange in the spring.
JR Products 160-85-A-26-A Polar White City Water Flange with 1/2" MPT
  • beemerphile1 wrote:
    Correct method, do it with no pressure and gravity will do the job.
    Not in my case. The flange is higher than the inlet line assy.
  • I turn off the pump, open a faucet, then go put something in the seat of the valve, like a wire tie or bread twisty. Something that won't damage the oring. Then go in and bump the pump on for a second. Presto! line filled with antifreeze. Remove bread tie and move on with your day. As long as the water is pushed out, the air doesn't matter much if there's a little bubble left.
    A faucet inside the trailer will always be higher than the inlet!
    That's a good point....I'd just have to do the city water line last.
    THE BEST SUGGESTION yet. And the simplest. :)
