i am almost posative i blew the o ring on it while winterizing... my question is do i need to replace it? We are seasonal so we only use city water not fresh water from tank.Thank you
When I was winterizing this past fall the little white ring blew off of the junkie little check valve. I found the ring and re-assembled the valve. It had a tendency to leak a little when using the pump without the city water hooked up. I went to the hardware store and picked up this nifty brass ball valve that screwed right on. The original rubber dust cap still fits.
