luvourtoys's avatar
luvourtoys
city water inlet
We need to replace the city water inlet connection on our 2007 PUMA, I cannot find a suitable replacement that fits the hole pattern on the trailer. Any advice before I contact the manufacturer? Thanks!
  • I replaced mine with a locking hatch type with square door similar to this one except it mounted using a larger round hole I cut with a hole saw.
    I also replaced the gravity fill with one using a larger round hole and square door.
  • has your rv dealership you went to tell you they make many different inlets and you really should take it in so they can see and touch which one you need to replace your original. it is like vent lids, they make so many different ones you need to at least take in the hinge for replacement match
  • Check out eBay and Amazon.
    You should be able to find the exact same part.
    Seal any screw holes and install a city water inlet that otherwise fits.
