FishOnOne
May 24, 2017Nomad
Lynnmor wrote:Trackrig wrote:
Am I missing something here? On the 5W-40 list, which is what the Rotella T6 is, I don't see the Mobile 1 or Amzoil oil there either?
Bill
What you and everyone else are missing is the fact that the diesel oil has been changed to make the government happy. Anti-wear additives, that have been used for years, are now reduced or eliminated. The new oil will cause more wear and companies like Ford have tested and found that many of the new oils are unacceptable.
The latest T6 is one that didn't pass the tests. Also, during the transition, there was some of the CK-4 T6 bottled with only the CJ-4 marking.
Regardless of what brand of diesel engine you have, the oil is now inferior to the previous version and more wear can be expected.
The brands (Rotella, Motorcraft, Cononcco Phillips, Valvoline) I listed earlier in the 15W40 version did not reduce anti wear additives and in some cases these additive were increased.
It's the DELO and Delvac with a CK4/SM API duel diesel and gas rating that you need to be cautious when using since these reduced zinc and phosphorous levels.
