Grit_dog
May 26, 2017Navigator III
Lynnmor wrote:Grit dog wrote:Lynnmor wrote:FishOnOne wrote:
The brands (Rotella, Motorcraft, Cononcco Phillips, Valvoline) I listed earlier in the 15W40 version did not reduce anti wear additives and in some cases these additive were increased.
For our trucks, the normal oil is 10W-30. 15W-40 is for temperatures above 20 degrees. I see temperatures below zero at times so there are few options left.
There's a lot of 5w 40 syn oils out there as well. OOD (obsessive oil disorder) can get the best of some though and they get lost in an oil debate when they could be out changing the oil in their vehicle.......
You did see the list of approved oils I posted earlier? Use whatever you want, I like to make an educated decision.
Yes, I did thanks. Let's just agree that our educated opinions come from different experience.
I've been around, maintinaed, repaired, operated and/or owned literally I'd say a thousand Diesel engines in various forms from 100T haul trucks and 200klb excavators to pickups, gen sets and light plants. Even had a few diesel roto tillers to keep running back in the day. I'll stick by it's not what you put in for oil (within reason) rather whether you maintain the engine properly or not.
SOME mfg reccomendations are totally valid, some not so much, some not at all. Kind of like 3/4 ton truck payload discussions....
Cheers!
