- sandhillsExplorer
BurbMan wrote:
NevadaMom wrote:
To piggy back on my towing confusion ...
On their website (rvmaxx) two of the TT models I was interested in are advertised as being 20' and 21' feet, yet when I started digging around and looking at reviews, etc, they appear to be longer. Short of taking a tape measure and traveling to the rv lot, how does one know the exact length of TT's?
And if the length isn't accurately stated, is the weight?
Welcome NevadaMom! Regarding length, the model number used to indicated length, but mfrs have gotten away from that. In my case the 280FQS in our model # once upon a time meant 28', but our's really measures 32'. You have to look at the spec sheet for the trailer (easy to find on the mfrs website) to see the actual length. Also note that some mfrs include the tongue length and some you need to add it in. the tongue is the V-shaped part on the front of the trailer that connects to the tow vehicle.shorteelaw' wrote:
From what I have gathered the tongue weight is the amount of weight put on the truck from the trailer which reduces the payload which is how much weight the actual truck can carry. Extra passengers and cargo within the truck all take from payload too.
Correct!
Here are some quick bullet points:
1. The weight of the trailer is split between the axle(s) and the tongue. The tongue weight is usually 10-15% of the total weight of the trailer, with 13% being average.
2. The Gross Vehicle Weight Rating (GVWR) is the most the Sequoia can weigh. Find that number on the driver's door jamb sticker or in the owners manual.
3. Subtract the weight of the empty vehicle to determine how much additional weight the vehicle can carry, also referrred to as "payload".
4. The "tow rating" of the vehicle is usually a maximum number and assumes that only the driver is aboard the vehicle, Any passengers or extra weight subtract pound-for-pound from this rating.
5. The average family adds 1000 lbs of stuff to the "dry weight" of a trailer. Trailers are weighed when they leave the factory and that weight will appear on a yellow sticker inside on of the kitchen cabinets, usually above or under the sink. The "dry weight" in manufacturers brochure is the base weight of the trailer without options like awning, spare tires, etc. If you are looking at a trailer with an advertised dry weight of 5000 lbs, figure it will weight 6200 lbs after you pack it for camping with clothes, food, pots/pans, etc. Fresh water is extra at 8 lbs/gal.
First thing is to pack the family in the Sequoia and head to a scale. You can find scales at truck stops, moving companies, scrap years, landfills, etc. Just drive on and they charge $7-$10 to tell you how much you weigh.
So I'll make some numbers here to illustrate:
The Sequoia loaded with the family crosses the scales at 6600 lbs. the GVWR sticker on your door says max weight can be 7200. So 7200-6600=600 lbs is available to carry the tongue weight of the trailer.
If the average tongue weight of a loaded trailer is 13%, the 600/.13=4615 total trailer weight. Subtract the 1000 lbs of stuff you added and that gives you a target dry trailer weight of about 3600 lbs.
What I did here was use the weight of the truck to work backwards to estimate what size trailer you can safely tow. So in other words, in this example, if I buy a trailer that weights 3600 lbs dry weight, add 1000 lbs of stuff to it, and 13% of that weight is on the tongue, my Sequoia will be within its weight limits considering both the weight of the trailer and the passengers.
For light trucks and SUVs, if you are within this weight rating for the vehicle, you are guaranteed to be way under the tow rating.
Let me know if this makes sense.
Burbman,
So tell me if I'm correct or not using your explanation....my GVWR is 7,200 and my loaded truck is 6,300. So I have 900 left to carry tongue weight. The tongue weight of TT im looking at is 485 lbs...so thats about 12%....take the 900/12% and I have 7500...minus around 1,000 lbs of stuff in the TT and I can be looking for a TT in the dry
6,500 range? Is that correct? - legolasExplorerrbpru - Dude, you did mean "Angels" didn't you....I am having so much fun reading this thread it should be against the law......pompousity and ego always a hoot
- ShorteelawExplorer
2112 wrote:
To respond to the OP asking about the F150 Ecoboost:
Look at the payload numbers carefully, even on the Max Tow models. They are not all the same. Options eat into the payload. I know too many people that bought EB's thinking they can tow the world only to realize after the purchase that their payload was 1200 - 1400 lbs, not over 2000 lbs as they wanted.
I found a stippo model on the lot with decent payload and felt real lucky I did.
My suggestion: Find the TV you can live with, but don't buy it yet. Then find your TT that the TV can realistically tow. Once you are happy with the pair, purchase.
Good Luck and see ya at the CG
Great advice and exactly what we are planning to do. Thank you so much! :) - 2112Explorer IITo respond to the OP asking about the F150 Ecoboost:
Good Luck and see ya at the CG - NevadaMomExplorerAnybody want a couple of teenagers? Haha.
Yes, we all ride in the Sequoia. There is no second vehicle. I guess our towing options are becoming severely limited.
Up until now, we've always towed a cargo trailer to haul all our (tent) camping supplies. Mom was just hoping to upgrade.
Looks like we'll take a family field trip to a scale and go from there.
Thanks for the wonderful education, even if it's not exactly what I wanted to hear.
Sandy. - BurbManExplorer III
Correct!
Let me know if this makes sense. - brulazExplorer
NevadaMom wrote:
I have a 2012 Toyota Sequoia 4.7L with a GVWR of 7300 lbs. I have six teenage boys (plus one little boy), which I know will obviously impact the overall weight.
Do all of you travel in that Toyota? If so, I suspect that with Six teenagers, One Mom and One child, that Toyota is already filled to its capacity. And adding a trailer's tongue weight will cause it to exceed its GVWR of 7300.
But that depends upon how heavy everybody is. Add up all your weights and compare that to the Toyota's payload on the doorjamb yellow sticker.
Or take two cars.
And trailer lengths are variable. Some just report the length of the box and, as mentioned, you have to add the length of the A-Frame. Others report the actual length from hitch to bumper. It depends. - GoldstalkerExplorer
You have to add about 3ft for the tongue. Also the dry weight stated will be approx 200lbs less than the actually unloaded weight after dealer options are installed. - NevadaMomExplorerTo piggy back on my towing confusion ...
And if the length isn't accurately stated, is the weight? - ShorteelawExplorerFrom what I have gathered the tongue weight is the amount of weight put on the truck from the trailer which reduces the payload which is how much weight the actual truck can carry. Extra passengers and cargo within the truck all take from payload too.
44,070 PostsLatest Activity: Sep 18, 2026
