brulaz
Mar 26, 2014Explorer
BurbMan wrote:
Typical travel trailer is 8' wide by 8' tall = 64sf. If you consider how high it sits and not just the area of the front cap, then 8' x 10' = 80sf. It would seem that the 60 sf is a limit, ie do not tow anything bigger than 60sf frontal area. It doesn't tell us what the relation between weight and frontal area is, ie, if 80sf is 33% over the 60sf limit, does that mean you de-rate the 11300 by 33% to 7533?
Like others have said, it's really %TW and receiver rating that determines tow capacity.
The only way you'll get to 11300# without exceeding the truck's receiver rating is with 10% tongue weight. And you really don't want to do 10%TW with a TT with 8' high walls and 64sqft frontal area.
But, offhand, let's say 12%TW will be ok with 60 sqft frontal area, and the receiver could then limit total trailer weight to ~9400#.
I've got ~ 66 sqft and about 15% tongue weight on a 7500# trailer. It's pretty stable in high winds. I would go down to maybe 13-14% but not lower, so maybe up to 8500# trailer weight max for 66sqft frontal area, as determined by receiver limits and %TW.
There's other factors than %TW and wall height involved in trailer stability (like load distribution in the trailer), but seems to me that the higher the frontal area - the higher the %TW is a good idea.
44,071 PostsLatest Activity: Aug 30, 2026
