Goldstalker
Mar 27, 2014Explorer
To answer your question I think you would be OK with the Titan and a trailer in that range. The Ecoboost would be better towing experience but to get both MAX packages you will most likely have to order one. The Ecoboost will tow at much lower RPM because of the Turbos, whereas the Titan will be doing 4k rpm up hills. Also to be honest the Titan is pretty long in the tooth at this point and gets poor mileage. I would recommend the Ecoboost for your situation but if you ever plan to get a bigger trailer or 5th wheel you will need a 3/4 ton.
44,071 PostsLatest Activity: Aug 30, 2026
