brulaz
Mar 27, 2014Explorer
Shorteelaw wrote:joshuajim wrote:
If you get an EcoBoost with BOTH max tow and HD payload it will be rated to tow 11,300# and has GVWR of 8,200# which gives you 2,600# of TV cargo capacity. That's roughly equivalent to previous generation 3/4 ton trucks.
You won't find one on a lot, they have to be ordered.
Would I need both of those to be able to safely a trailer that's about 6500-7000 pounds with everything in it (cargo/water/etc)?
A 7000# trailer could have a 1050# tongue weight (15%TW). My 7500# trailer does (1130# TW). You can get a Maxtow Eco with 2000# payload, I did off the lot, but it's a 4x2 SCab, not a 4x4Crew Cab. And it doesn't have a lot of options.
So figure 1000# TW add 50# WDH weight and add up weights of everybody and everything that will go in the truck in addition. Then find a truck with the Yellow Sticker on the Doorjamb Payload to match, or higher.
44,071 PostsLatest Activity: Aug 30, 2026
