VictoriaChan's avatar
VictoriaChan
Clipper 17FQ propane update
This might be a stupid question, but I am kind new to RV.
I only have one propane connection and can only carry one tank. But I am full time RV user.can I buy a two stage(?) propane connection to replace the current one?
  • Single axel TTs need QUALITY tires properly inflated/checked daily with a load range as high as you can find.
  • Old-Biscuit wrote:
    Your small trailer currently has only ONE propane cylinder.
    You would have to have a double cylinder platformed installed on trailer tongue and then add second propane cylinder and an auto changeover regulator and add'l pigtail hose to connect 2nd cylinder
    Doable...sure
    Are you a 'traveler' or 'stationary' full time user
    Traveler..dual cylinders
    Stationary...have local propane company deliver/set up a 100# propane cylinder which they come fill as needed
    Not traveler, but move 2-3 times a year based on workplace in state.
    Probably a good idea to contact about big tank.
    Thanks
  • Sure you can, as long as you have room for another tank.
  • Your small trailer currently has only ONE propane cylinder.
    Doable...sure
