VictoriaChan's avatar
VictoriaChan
Clogged drain, any solution?
Shower drain clogged. Other drains work fine.
Some times the water in the show tub just go through the next day, sometimes not.
Tried toilet plunger, some water will go when I use it; but the rest will not.
Nothing put into the drain, double filter.
  • I would first verify the tank is empty then use some liquid drain opener from Home Depot. I use the commercial grade black bottle. Let it work a couple hours or overnight. Repeat weekly until back to normal.
    Otherwise something got past the filter besides hair and soap that will need to be removed by opening the pipe fittings.
  • MFL wrote:
    Can you access the p-trap underneath, to remove and clean out? Mine is easily accessed from the pass through.
    Jerry
    I can't see any access panel, it's actually shower pan with panel surrounding.
  • Can you access the p-trap underneath, to remove and clean out? Mine is easily accessed from the pass through.
    Jerry
