Sea foam is a major no-no in diesel fuel, it will emulsify any water to the point where it cannot be separated and will go thru the injectors.
just me wrote:
Cummins does not recommend any additive. Cause the tolerances are so close, additives might loosen some junk and might foul up the injectors. Remember they are like GOLD if you have to replace them out of your pocket. Good clean fuel only.
No manufacturer can recommend them, it would be tabu to make an engine or fuel system that needed additives.
That being said there is a complete line of additives from Fleetguard, aka Cummins Filtration. What does that say?
The loseing up junk is a misnomer, that's what fuel filters are for. If you have junk in the fuel sustem between the filter and injectors then I have bad news for you, the damage is unavoidable.
ULSD is a much drier fuel and requires additive to have enough lubricity, the fuel stations/distributors are supposed to add this. Do you trust them to not forget?
I run Amsoil diesel concentrate every tank, and always have, so I cannot comment on effectiveness, but I like the added lubricity, fuel stabilization, and cleaner. Then again I run 2 additional fuel filters since I want to protect my fuel system a little better than OEM does.
To the OP, the current software for the 07.5-12 6.7 is much better and failures are now very rare. That being said they do take heat to do ther emissions business. If you do lots of short trips run a winter front, even into spring. Also one the motor is above about 140 use the exhaust brake as often as possible, it add/maintains heat and keeps the turbo turbine vanes clear of excess soot buildup. I do t recommend doing it instantly in a cold motor as the backpressure and dirty combustion can easily put excess soot i to the oil before the pistons and cylinder walls warm up.
Don't idle cold, ever. This is one of the worst things you can do for a diesel (6.7 or not). A diesel takes too long to warm up without a load, so just idling is hard on the motor and produces a dirty and incomplete combustion. If you want heat faster on a cold morning get an outdoor timer and a use the block heater in conjunction with the winter front.
You don't have to drive it like you stole it, but it does need to be driven with a little higher power production from time to time.
