Ex-Tech
Aug 08, 2014Explorer
Bagger97 wrote:
Check your circuit breakers first. The converter has nothing to do with the AC or water heater. It's only for 12v items like the frig and lights. You might have popped the main breaker. Bigger question is what did you really plug into? If it was 220v you could have blown every appliance in the trailer.
Actually, the water heaters rely on 12-volts for gas operation on a Direct Spark Ignition water heater and the air conditioner needs 12-volts for the circuit board if a ducted type unit.
44,056 PostsLatest Activity: Nov 19, 2013
