lawrosa
May 26, 2017Explorer
BlueridgeCoachmen wrote:
Oh, Sink covers are standard on Coachmen Catalinas. I,m with you on not having slides on a RV. We,ve had,em and they are a pain. Plus they add extra weight.
Sink covers are an option in 2018. I ordered my unit was actually supposed to be a 2017 but delays in the built pushed it out..So when the dealer put my order in there was no sink cover option..
The only options I had at the time was the full wall.
Other options were 15k btu a/c
two 30 lb propane tanks.
This has the latest and greatest tpo roof.. ( I dont know is thats a good thing)
Eeeekkkk! I drilled holes in the walls the mount my two tv's. But its over and done with..
Getting some foam toppers to add to the two inch bunk mattresses..They are pretty firm . The master is like a 6" foam block. Again very firm..
Added a few brads nails to the dinette fasia kick boards ar the staples are a lot to be desired.
The shower head could of been mounted a whole ft higher. ( Im wondering how to fix that. If I move the shower head holder then ill have two screw holes there.)
I guess I need a better shower curtain..
Still hating the windows...lol
Got a digital t stat coming...Was going to make my own with a fan hi/lo switch but I wanted a black t stat. Was only 47 bucks on amazon...
LED lights are bright man.. front wall switch turns on 4 of them. Will look into dimmer options. M4 bulbs had two options for dimmers...
HWH has an anode.. I dont know if thats good or bad... I assume its glass lined. Im a plumber and my last camper didnt have one. I assume aluminum. I drained after each use.
Tires are 81 MPH jaxxons.. They seem well made...
Currently hooking up my charge controller and invertor in the front storage bay. work in progress...
