shedberg
Apr 19, 2015Explorer
Coachmen Clipper 17BH - replacement propane hose?
On my Coachmen Clipper 17BH I have swapped out my 12v battery for two 6v batteries. The battery box that I am now using houses both of the 6v batteries.
The problem I am now facing is that the propane hose that goes from the trailer to the propane tank no longer reaches over the battery box to the propane tank. I believe all I would need to do is replace the hose that goes from the regulator mounted on the outside of the trailer to the propane tank with a longer hose. However, when I look for replacement hoses I see a vast amount of confusing choices (high pressure, low pressure, accessory, etc.).
Any recommendations on what I need? I am assuming if the hose was 48" long, it would allow for plenty of room to make it around the battery box and connect to the propane tank. Thank you for the help!
