SoundGuy
Nov 30, 2017Explorer
mountainkowboy wrote:
I also like that it can be towed by our Ranger, 5,900lb tow capacity, with a moderate load out for local and weekend play too.
Maybe, I guess it depends on your expectations. I know forum member Last Train tows his own 192RBS with a Honda Pilot but I personally wouldn't be comfortable towing it with anything less than a V8 1/2 ton gasser, such as my Silverado.
Thanks for the heads-up on the water tank issues, I will have to remove the underbelly cover and see if they have addressed that. If not, I will make supports for it similar to SoundGuy's.
To be clear, the only tank that IMO isn't supported properly is the fresh water tank. I've never had any problem with the grey or black tanks, the latter of which always has content on the way home from a camping trip as I never dump at the campground but always service my tanks at home using my FloJet Waste Macerator. If the tank is full it does unload the tongue somewhat but it's never been an issue in terms of handling, even without sway control which I don't use.
