SoundGuy
Dec 09, 2017Explorer
TheHound wrote:
Curious, where would the changes from 2017 to 2018 be posted or would you need to contact a dealer? Wondering if they made some tweaks on those items you highlighted.
SoundGuy wrote:
I suspect any changes between '17 and '18 models are cosmetic - interior colours but more notably the use of white skirting & trim on the exterior rather than the traditional dark brown / black. Personally I'd rather see manufacturers put more effort into improvements that actually matter, such as proper tank support or upgrading the tires to Goodyear Endurance such as Jayco is now doing, and not just window dressing that they believe will increase sales. In any case, I'll be tossing a cover on mine on Sat so I'll try to remember to ask about any differences.
TheHound wrote:
OK, if you find out please let me know. And I completely agree about making changes that will improve safety and reliability vs adding some pretty colours.
So I installed my cover today and as promised took a look at 2017 / 2018 Coachmen Freedom Express models while at the dealership. Exterior graphics are a bit different, exterior trim & skirting is traditional dark brown / black on the 2017s but a startling white on the 2018s, both have LED lighting on the front nose cap. A 2017 Freedom Express can be seen on the right is this pic, 2018s have blue added to the graphics.
Dealer has two 2017 192RBS units, one was being prepped in the shop as it had been sold, the other was still on the lot and is this one.
The dealer is sold out of 2018 192RBS models and is awaiting more to be delivered so in the 2018 year I took a look at other models in the lineup. A 2018 204RD had a enclosed underbelly but did not have any external fresh water tank support ... not sure why as a 2018 257BHS beside it which also had an enclosed underbelly did have 2 external fresh water tank supports. The 2017 192RBS also had an enclosed underbelly and also did have external fresh water tank support braces, as shown is these two pics ...
However, as can be seen these tank support braces are made of really thin metal and are bowed noticeably, no doubt because the trailer has gone through PDI and has had water added to the tank. The 2018 257BHS tank support braces were the same thickness steel but were not bowed so I'd presume this unit had not yet had water in the tank. The other thing I noticed is that while the fresh water tank on my 2014 192RBS is mounted above the axles these tank supports are well forward of the axles so I'd presume the fresh water tank is now mounted further forward on this model than it used to be. This tank support is an improvement but if I were buying one of these units I'd immediately replace those tank supports with much heavier steel, ones that won't bend when the tank is full of water. As for the enclosed underbelly I personally didn't care for it as it means you can't see anything except the gas lines which interestingly run along the underside of the Coroplast. Whether the water pump connects to the bottom of the fresh water tank as it should or still connects to the tank sidewall I can't say because it's hidden by that darned underbelly. Overall my 2014 holds up well against the new ones but I do like the 2017 because it has a full length queen bed, a vent over the main cabin (both of which my '14 doesn't have), the molded front cap, and the dark brown / black exterior trim & skirting which is the same on my '14. Sure don't care for the change to white trim & skirting on the 2018s but of course that's personal taste.
