SoundGuy
Dec 10, 2017Explorer
drsteve wrote:
The Coachmen in my sig, purchased in July, has the same issue with the fresh tank. Fill it up and watch the enclosed underbelly sag.
I will address that problem in the spring, when I pull the coroplast to figure out why the floor creaks and cracks and flexes when I walk past the kitchen counter.
Don't know whether this will help but I found with my own 192RBS that it wasn't the floor per se that was creaking but the kitchen galley cabinet that would flex slightly when walking near it, causing a bit of a creak as it rubbed against the floor. My solution was to run a lot more screws through the cabinet and into the floor. FWIW, when walking through a new 192RBS on the dealer lot it did the same thing - creaked a bit near the kitchen galley. Ideally the manufacturer would have used some sort of rubber gasket between the kitchen galley and the floor but screwing it down more tightly seemed to work pretty well for me. :)
