concord_05's avatar
concord_05
Coachmen Freedom Express 276
Just bought a CFE 276 trying to set up the tvs. It has two hook ups on the outside. The left side says cable/satellite and the right one says cable. Above the living room tv is two cable hookups. I hooked the tailgater to the left outside hookup and the z211 receiver to the left hookup inside and am receiving satellite tv. I'm thinking the right coax hookup inside is the Over the air antenna. (The trailer is in a garage and we are too far away to receive OTA signals to check it out). Also thinking maybe the outside hookup on the right that says cable is to the bedroom tv. Is this correct? If this is the set up, how do you hook the bedroom tv to satellite ?
    I suspect you probably don't ... feeds inside the trailer are usually routed from the cable / antenna wall plate with the one on the front feeding the main television and a second output on the back side of the wall plate going to the television in the bedroom ... no provision for satellite feed routing, so if that's what you want you'd probably have to add it yourself.
  • Coachmen Freedom Express model 276. Travel trailer by forest river. 2017
  • concord 05 wrote:
    Just bought a CFE 776 ...
    Interesting ... as a Coachmen owner myself I've never heard of it. Any more details? ... year, type of trailer? ... or is it even a trailer? :@
