myredracer's avatar
myredracer
Explorer II
Jan 17, 2014
Code & safety requirements
I just scanned through the NEC article 551 that specifically covers RVs. Seems to cover pretty much anything electrical to do with an RV.
My question is, is this for manufacturers only? What happens if an RV owner does substantial modifications to the electrical system and/or components. Is he/she supposed to do any work in accordance with the NEC and should they be taking out a permit? What would happen if the modifications were improperly done and there was an electrocution or fire?
I've read many times about owners doing modifications themselves like upgrading their panel from 30 to 50 amps for example. If it were a house, you'd be required to obtain a permit and have it inspected.
Same goes for work on the LP system and appliances. Is there a Gas Code that is similar in it's requirements? What if someone does extensive changes to the LP installation?
Is there a correct procedure that you should be following to have your work inspected and approved or is this something that just falls through the cracks?
Are RV techs specifically trained and licensed to do electrical and LP work?
