Duramaximos
Apr 22, 2014Explorer
COG - I broke a cardinal rule...go easy on me
So...months of research and shopping and the wifey and I recently settle on our first truck camper.
I'm talking about a 2006 Okanagan 106 UDB. The TC is perfect for us with respect to amenities and the quality appears top notch.
Did a bunch of reading and research but after all that, still made the mistake of taking it for granted that this "long box" designed camper would provide a center of gravity ahead of the front axle of our 2012 Silverado long box dually...you would think right?
It turns out the centre of gravity point is approximately 2" behind our rear axle. With no turning back on our deal I'm seriously considering selling the camper (which will be hard to swallow at this point) and looking for something more appropriate, unless I can find a glimmer of hope from the forum members here.
On the long highway ride home, we found the camper and truck combo felt a little floaty on some road humps, and a little bit of porpoising (so I've heard it called). I believe some of these things are symptoms of the TC weight being too far back.
So after that lengthy intro, my question is, can the camper be loaded in such a way to make a significant difference to the centre of gravity?
I do believe the fresh water tank is forward of the axle, and the fridge is forward of the axle. However, grey and black tanks are aft, and the 2 30# propane tanks are aft. Currently the TC is empty with the exception of the propane tanks which are full.
Now to make the challenging question even moreso, we intend to tow a 20' Thunderjet boat attached to an 18" hitch extension - I know, I don't ask for much :) I suspect the tongue weight on the boat trailer will be about 500#
If it matters any, the truck is a diesel so it's not exactly a light weight on the front axle.
Thanks in advance for all your suggestions!
Don't be afraid to pull any punches...like I said we're prepared to sell the new camper if we can't find an appropriate solution.
Thanks.
Thanks.
