Kayteg1 wrote:
burningman wrote:
Let’s say you’re miles from nowhere and your truck quits running.
Would you rather be in a ‘77 Chevy or a ‘17 Ford? I can tell you which one you have a better chance of getting running.
With 2017 you plug-in Bluetooth adapter into OBD, fire up TorquePro on your android, clear the code and be on your way :C
Takes about 45 seconds assuming you don't have the adapter plug-in already.
Because, a code needing to be cleared is all that can go wrong... not!!
You just rattled off several more layers of things that can all fail.
Anything having to do with an electronic glitch and sets a code doesn’t happen in the first place on a ‘77.
