Community Alumni
Jan 29, 2019Not applicable
Grit dog wrote:IdaD wrote:
Run full synthetic oil and don't worry about the diesel or any additives - if you live in a cold climate the stations will sell winter blend diesel in the winter months.
I agree with this aboout 99%. The one caveat, is fuel "should" be treated to the expected low temps for the geographical area and season, however that is not 100% the case if you're dipping into record low temps.
I only say this because I witnessed the entire Denver metro area caught with their pants down figuratively when there was a -25 to -30 deg cold snap and the local fuel was not treated to that low of temperature. I drove 4 hrs round trip to buy cases of 911 to get our equipment running, while zig zagging the obstacle course of gelled up diesels on the road!
THIS!
I would normally not recommend the need for any anti gel treatment if you're buying fuel from the local area, but right now in the upper midwest, would be about the only time I'd dump anti gel treatment in the tank.
Or like last month when I fueled up near Vegas and drove to the Wasatch mtns. Went from 60deg to -10. Truck got a dose of PS since I had half a tank of fuel from a warm climate. The trigger was, as one left Vegas getting to St George, stations were advertising "winter conditioned" fuel. Told me the fuel in the desert likely wasn't treated for low temps.
Otherwise, yeah when it's that cold, if the truck is parked in ambient temps, plug it in. Makes starting much easier.
THIS! I have also experienced jelling with "local" fuel and it was not fun. While most fuel dealers will provide a treated fuel for the area it may not be 100% and you don't want to stop at that one dealer who may have brought in fuel from a warmer climate without treating it. This happened to some of us years ago and it was a major named company, but a locally owned station. I believe that adding an anti jell additive in cold weather is cheap insurance to keep your equipment running.
44,071 PostsLatest Activity: Aug 30, 2026
